We manufacture components out of honeycomb panel. This particular joint is like welding 2 c-channel members together, although one member is made of 0.018 CP1 Titanium sheet and the other is 0.025" CP Ti plate.
This is a butt weld
Manually welded using Wp-9 torch and trailing shields. The trailing shields were made by the welders and have been working well for years. However, I am trying to make the switch to off the shelf trailing shields for better consistency.
The welds have been coming out silver with no discoloration within in the HAZ. The porosity is not on the surface and has been discovered once the part goes through x-ray. The porosity seems to be in the thicker member as well.
As far as specs, we have our own internal fusion welding spec that we use and the welders are certd per AMS-STD-1595A.
We have always had little areas of porosity with this particular joint in the past. Although, within the past couple of weeks, the porosity has been horrible. We had 3 different guys weld 3 different parts and they all had excessive amounts of porosity. It only seems to be on this particular part. I thought maybe they were using insufficient, or even excessive gas flow, but it seems odd that all 3 would be making the same mistake.
