Up Topic Welders and Inspectors / Welding Equipment Classifieds / Need exciter coil set
- - By DLWood (*) Date 11-24-2007 18:20
For code number 5642. Not wanting to spend the money for new right now.
If not then from Hybriweld or Weldmart? Ant difference?
dlwood78023@yahoo.com
Parent - - By raftergwelding (*****) Date 11-24-2007 20:52
i need the year model off the machine i have a 54 short hood i'm parting out i think there is a difference in the coils between a short and long hood but i might be wrong i'll have to ask a few people and get back to you all you need is the coils right?
Parent - - By DLWood (*) Date 11-25-2007 01:09
Not sure of the year, the faceplate is missing. And all I need is the coils, as far as I know.
Another question though. Newer code machines have a higher aux DC output at the outlet, 9 vs 15 amps. Is this due to the coils or the armature or both?
Parent - By raftergwelding (*****) Date 11-25-2007 01:22
not sure how you're checking it but my machine reads 117 at the plug sounds to me like you need to recheck at high idle is your armiture housing round or octagon shaped the 54 i have i am parting out and to save you some time and trouble i will sell you the complete back half of the machine excluding the armiture and exciter for 500
Parent - By raftergwelding (*****) Date 11-29-2007 04:54
i'm not sure on the higher dc output on different machines that would be a question for Kaye at bills welder repair she is on the forum under KSellon very helpful and very sa 200 savy
Parent - - By KSellon (****) Date 11-30-2007 20:00
http://www.mylincolnelectric.com/Catalog/operatorsmanualdatasheet.aspx?p=28744
exciter field coils L8707. The only diference is the way they're wired internally in the field housing. Thus the reason you have to turn your rheostat to 100 for full output on the older machines and not on the newer ones.
New with 1 year warranty ( if properly installed) $245
Have you lost 110? and thus lost weld? Email me and I will give you the ohm readings to check your coils.
Parent - - By raftergwelding (*****) Date 12-01-2007 04:05
Kaye is that price for copper or aluminum coils wow i was told 250 for a used set wow i'm getting ripped off down here if that price is copper that or you got some secrets up your sleeve i dont know about and no i aint asking for your secrets
Parent - By KSellon (****) Date 12-03-2007 15:51
100% copper. Brand new. You are being quoted list.
Parent - By HYBRIWELD (**) Date 01-24-2008 06:18
ALL OF OUR EXCITER COIL SETS ARE NEW AND MANUFACTURED BY US...
200 AMP REGULAR EXCITER COIL SET: $250.00
HEAVY DUTY: $350.00
Parent - By HYBRIWELD (**) Date 01-24-2008 06:27
WE ONLY USE 100% COPPER AND THE MOST PREMIUM WIRE GRADE AND INSULATION.
