Up Topic Welding Industry / General Welding Discussion / how does this weld look?
- - By WelderShane Date 11-30-2007 00:57
i was using a lincoln weld pak, flux core wire. hows is this one? im still learning. thanks
http://i177.photobucket.com/albums/w...27/myweld2.jpg
Parent - - By WelderShane Date 11-30-2007 00:59
Parent - By Sourdough (****) Date 11-30-2007 02:54
Looks good, 'cept you didnt finish it.
Not finishing a weld all the way around is kind of like getting a barbedwire tatoo that doesn't wrap all the way around your arm, even though it hurts like hell..........
Parent - By bozaktwo1 (***) Date 12-03-2007 17:43
A little too fast to start, then you slowed down...then you need to stop and fill that crater.  Otherwise, not bad looking at all IMO.
Parent - - By wisker stemmings Date 11-30-2007 03:20
work on you weeve, your moving to much, let the puddle build, before you move, work on your stops and starts, looks like you could have a crater crack?
Parent - - By nick thompson Date 11-30-2007 21:57
the tat thing was right on. yeah man finish it!!!!!!
Parent - - By WelderShane Date 11-30-2007 23:41
Thanks. yea i didnt finish it because i didnt want to waste my wire. i was just testing on a scrap piece.
Parent - By JMCInc (**) Date 12-01-2007 06:10
Be careful of that car in the back ground, auto glass and sparks don't mix well.
Parent - - By 803056 (*****) Date 12-01-2007 16:37
You will have much better results if you grind the scrap steel before welding on it.
Parent - By darren (***) Date 12-02-2007 08:58
you are almost always so polite al
Parent - - By Kix (****) Date 12-02-2007 05:45
It might be good enough to hold shelled corn.;-)  Kidding..  Looks real good for the process your using. I LIKE IT!!
Parent - By NDTIII (***) Date 12-03-2007 03:54
What am I the only one that sees the udercut?
