The electrode mfgs give you those suggested parameters to use to get you in the ballpark, but then the welder must fine tune his machine from there. These values are generated from extensive testing so that you will have a good place to start. The numbers will vary with each electrode mfg, due to the "soup mix" that each mfg uses.
