Up Topic Welding Industry / General Welding Discussion / f350 coversion
- - By elliott (**) Date 12-17-2007 23:05
How it going everybody. Hope everyone is doing well. My quetion is does anybody know what is involved in taking a singlr rear f350 and converting it to a dually. Can you swap wheel if the studs are long enough or do you have to chang rearend.
Thanks guys
elliott
Wish you all a merry christmas and happy new year
i know this isnt the automotive section but I figured i would get more response here
thanks again
Parent - By rig welder6 (**) Date 12-17-2007 23:50
if you have one with the long studs, dana 50 or 60 you should beable to put dually rims on.  Im pretty sure but not pos. good luck.
Parent - - By thebandit501 (*) Date 12-19-2007 03:41
you will either have to change the rearend or the do sell a kit to change the single to a dually if it is a four wheel drive if it is then you must match the axle ratios but F-250 and F-350 both use dana 80 or ford 10.5 so you need to make sure which one you have.
Parent - - By JescoPressure (**) Date 12-20-2007 12:42
dont they run adifferent front diff on the duallys too?
Parent - By thebandit501 (*) Date 12-21-2007 04:16
yeah, I don't exactly remeber but some trucks have 10.5 other have dana can't remeber why they do it just to be a pain in the butt I guess
