Up Topic Welding Industry / General Welding Discussion / PROPANE TANK INSPECTIONS??
- - By TANKIE (*) Date 12-22-2007 17:22
I HAVE A 100 LB PROPANE TANK AND THE INSPECTION DATE EXPIRES NEXT YR I WAS WONDERING IF ANYONE KNEW WHERE I COULD GET IT INSPECTED?? LOCAL WELDING SUPPLY, PROPANE DEALER? ANY HELP WOULD BE MUCH APPRECIATED THANKS, TANKIE
Parent - - By dbigkahunna (****) Date 12-22-2007 18:41
If it is a portable tank, most propane dealers can do it. Cost around $25.
Parent - By TANKIE (*) Date 12-23-2007 19:30
THANKS IT IS PORTABLE, FOR MY 5TH WHEEL TRAVEL TRALER
Parent - - By thirdeye (***) Date 12-23-2007 19:37
I thought the 100# ones were exempt.  We have two from work that are from the '60s that have never been recertified to my knowledge.  The other day at the propane dealer, the guy helping me said he had one from 1946.
~thirdeye~
Parent - By webbcity (***) Date 12-23-2007 19:47
~thirdeye~ , dot is 12 yrs since new , mfg. date is stamped on it . next renewals have other limits i'll ask jerry today when i see him if i remember , i have to plow his snow today . good luck . willie
Parent - By rlitman (***) Date 12-23-2007 22:52
No, but larger tanks may be exempt from OPD valve requirements.
Parent - By webbcity (***) Date 12-24-2007 09:31
~thirdeye~ ,just got in from plowing snow , talked to jerry he said 12 yrs on first stamp and 12 yrs on renewal stamp . so that should answer your question . he's in alaska . good luck . willie
Parent - - By thirdeye (***) Date 12-24-2007 11:05
Thanks guys, I better do some checking.
~thirdeye~
Parent - - By TANKIE (*) Date 12-24-2007 15:49
THANKS FOR ALL THE HELP EVERYONE HAS GIVIN MERRY CHRISTMAS TO ALL!!
Parent - - By TozziWelding (**) Date 01-01-2008 00:00
If the tank has a fresh coat of paint, they usually fill it no ? asked.
Parent - By TANKIE (*) Date 01-02-2008 01:12
YES IT STILL LOOKS PRETTY NEW BUT THE DOT EXPERATION DATE IS IN BIG STAMPED # ILL SEE WHAT HAPPENS THANKS FOR ALL THE HELP AND HOPE ALL IS GOOD IN 08 THANKS TANKIE
