Thousands upon thousands of high pressure steam, low pressure steam, hot reheats, cold reheats, main steams, downcommers, by-passes, etc are done every year with wide weaves.
In fact, high heat inputs from wide weaves actually can be better (within some limits of course-I ain't talking 3 inches wide) for high temp applications. Large grains don't slide as easily in high temp applications.
And it does seem to be true that most people that have problems with wide weaves have a tendency to be AWS trained as opposed to ASME, where weave width is generally not an issue unless you are working to impact regimes.
