E29 "Standard Practice for Using Significant Digits in Test Data to Determine Conformance with Specifications"
.1 or .01 can make a big difference depending on the element in question, but as a mimimum, the difference between absolute and rounded values needs to be understood.
Either or, if the analysis is off spec, it's a mute point from my perspective. If the material as spec'd is out, is should not make it to the welding stage.
Gerald
