Up Topic Welding Industry / Processes / BRAZING OF #954 ALUMABRONZE
- - By all podition Date 01-16-2008 15:35
I use this product (954)  often, and i am left with 3-4 inch drops.  I would like to tack these drops together for sawing oddball parts.  I have tried the practices I use for # 660 bronze, ( silver solder, paste solder ) with no results.  the molten puddle will not wet to the parent metal.  Please advise.
Parent - By DaveBoyer (*****) Date 01-17-2008 06:30
As You only have to withstand the forces of sawing, and even some of the part You are sawing on will be supported in the vise I suggest You line the drops up on a flat table with one edge lined up against a streightedge and tape with filiment packing tape. Turn over and do the other side. I have actually seen this done with material that was milled to shape in longer bars and cut into sections about 1/2" thick. It worked better than I thought it would, the bars were about 2"x2". If the saw vise stops far from the blade use 2 strips of stock 1 placed each side of the work to extend the vise's clamping close to the blade.
