Is there technology that will allow the electronic transfer of radiographs via the internet? What is needed is the ability to somehow scan and existing radiograph (film type)and be able to view it. Is this technology out there? Thanks Dave
Yes there is. Digitizing radiographs has been out for some time. If it's on a one time basis, you'll probably find it cheaper just to ship the radiograph, if this is a one time multifilm then your going to be better off digitizing the film. if this is to be a permanent arrangement, then I would suggest skipping the film all together and moving into cr radiography in which you'll use plates that give you a digital image to start with.
