![](/mwf/attachments//avatars/19261-6136.jpg)
alternator, alternator bracket, adjusting arm, starter and coil, generator housing with a cut out for the starter nose, backing plate with hole for starter, flywheel with ring gear, start button, on/off toggle, choke cable, wiring.
If I tell you anmore of my secrets I am going to have to hire you, so this is what I will share this time
