We are considering changing shielding gases from a Helium tri-mix to a Argon/N2/Co2 mix for welding root passes in stainless pipe in the 1GR position. We weld to ASME section 9 codes. We have had some heated discussions whether we need to re-qualify are procedure. Does anyone know the code implications?
