Up Topic Welding Industry / Technical Discussions / How do thoriated GTAW electrodes work?
- - By - Date 08-09-2000 19:26
By what mechanism do thorium and zirconium, when alloyed with tungsten, change the character of the arc in GTAW? Welding handbooks say the alloying elements stabilize the arc, but they never say how or why. Were the beneficial effects of adding thorium and zirconium discovered by accident, or did some basic principle of chemistry or physics suggest adding thorium or zirconium would be a good idea?
Parent - By - Date 08-10-2000 13:35
Hi Ed,
The alloyed Tungsten electrodes (Zirconium oxide, Thorium oxide, Cerium oxide, Lanthanum oxide) contain these oxides which have higher melting points than pure Tungsten. Thus, they have a greater current carrying capacity resulting in longer electrode life, easier arc initiation and stability, and greater resisitance to atmospheric contamination (both of the electrode and weld pool). Pure tungsten electrodes are generally only preferable for AC welding of Aluminum (electrodes with Thoria additions have been known to split when used with AC). However, I personally like to use an alloyed electrode at all times, unless cost is a factor.
Hope this helps!
Joe17
Parent - By - Date 10-07-2000 21:22
Thorium is radioactive. The introduction of thorium into the electrode increases its current carrying capacity
Parent - By pdweldor (*) Date 10-09-2000 18:04
Go to Diamond Ground Products website. There is a good explanation on the function of oxides in tungsten electrodes. Basically the oxides have lower electron work functions, so it is easier to "boil" off electrons and thus arc stability is better and starting is easier.
http://www.diamondground.com/
Parent - By MBSims (****) Date 10-10-2000 02:24
Actually the thoria makes the electode last longer by retarding grain growth at the high temperatures seen in arc welding. The grains in pure tungsten want to grow to seek their lowest free energy state. Growth is faster at high temperatures. At high enough temperature and long enough time, the grain size would grow to the diameter of the tungsten and flake off. Having the thoria scattered in between the grains acts as a barrier that the growing grain must overcome before it can get bigger. That takes more energy, so growth is retarded. In reality, if you're like me you wind up dipping it in the puddle long before it has enough time to start flaking off. :)
Marty Sims
