My big 40 now sets in the shop,I don`t use it much. I`m only able to use it because I disconnected the center coil from the range selector switch. With it connected it would not weld, acted like it was under constant load,as in a coil shorted,which I assume it is. I disconnected the center coil from the range switch and now it will weld on the top three ranges,not the first two,also doesn`t seem as hot with this disconnected. Thought I`d try this and it does work,I just would not use it this way and depend on it for a welding job.I did not check out any diodes or anything else,just figured with smoke rolling out from the center coil and with it burn`t looking ,that was my problem. Still would like to fix it someday. Thanks for input.
