Bill,
Assuming the weld is not flush, the minimum prequalified weld size for BTC-P10 is equal to the tube wall thickness, provided the joint is welded with either SMAW, GMAW, or FCAW.
However, the prequalified joint details for the BTC-P10 flare bevel groove weld size is based on welds being flush, as indicated by note l .
