Up Topic Welding Industry / Inspection & Qualification / backing bars.....
- - By JA (**) Date 05-05-2008 02:57
when welding full pen grove welds , what is the maximun gap allowed between the base metal and the backing bar..........
Parent - - By 803056 (*****) Date 05-05-2008 04:37
I believe the D1.X welding codes list 1/16 inch as the maximum gap between the backing and the underside of the joint.
Parent - - By JA (**) Date 05-05-2008 12:40
where is this info located....?
Parent - - By Shane Feder (****) Date 05-05-2008 13:35
JA,
AWS D1.1  Section 5.22.1.1
Shane
Parent - By 803056 (*****) Date 05-06-2008 03:09
Thanks Shane. I'm on the road this week and don't have D1.1 with me.
Best regard - Al
Parent - - By JA (**) Date 05-06-2008 03:42
thank you......
Parent - - By Bill M (***) Date 05-06-2008 18:47
If these welds get UT (ultrasonic testing) I would push for a tight gap.  I have seen some large gaps under the backing bar contribute to some tough UT calls.
Parent - - By eekpod (****) Date 05-06-2008 23:40
What happened to the wording of "intimate contact?"  I don't have my code book at home but I believe that's the wording they use.  The backing bar shall have intimate contact with the member being welded.  I'll have to try to remember to look this up tomorrow.  Chris
Parent - By Shane Feder (****) Date 05-07-2008 06:34
Chris,
5.22.1.1 Faying Surface. The separation between faying surfaces of plug and slot welds, and of butt joints landing on a backing, shall not exceed 1/16".
The only "intimate contact" I know about has nothing to do with welding. LOL!
Hope that helps,
Shane
Parent - - By CWI555 (*****) Date 05-07-2008 11:37
I don't believe it's ever been "intimate contact". Going back to 75 D1.1 It states:
3.3 Assembly;
"The seperation between faying surfaces of lapjoints and of butt welds landing on a backign shall not
exceed 1/16"
I believe you've gotten this confused with another code. I've seen/heard the terminology used before,
but not in association with D1.1
Parent - - By Lawrence (*****) Date 05-08-2008 15:29
Maybe this is what brought that term to mind.
D1.2 2003
4.7.1  Positon
. Backing shall be in
intimate contact with the root side
of he parts being welded.
Parent - - By jwright650 (*****) Date 05-08-2008 15:45
Good find Lawrence!...I have seen it too, but couldn't remember where.
Parent - - By swnorris (****) Date 05-08-2008 19:13
I guess Lawrence has been in intimate contact with D1.2
Parent - By jwright650 (*****) Date 05-08-2008 19:13
LOLz....
Parent - - By CWI555 (*****) Date 05-11-2008 15:59
LOL
Parent - By eekpod (****) Date 05-11-2008 21:04
well at least I'm not crazy.  I knew it came from somewhere.  Nice job.    thanks chris
