Hello elliot, please forgive me if this sounds too simple. Is this the type of cutting attachment that screws onto the standard victor torch body? In other words, is this a combination torch? If so, you need to attach it using only a hand-tight amount of force as it does have O-rings for sealing and if they aren't sealing properly with a hand-tight application they won't seal any better with a wrench and a wrench should never be used for making this connection anyway, Next, the oxygen valve on the torch barrel should be fully opened, this will provide the proper cutting oxygen flow when the cutting lever is depressed, the actual torch preheat flame adjustment should be accomplished by using the acetylene valve on the main torch barrel and the oxygen adjustment of the preheat flame should be done with the single valve on the cutting torch attachment portion of the assembly. If you try to adjust the preheat flame for the cutting torch by using the two valves on the main barrel assembly, depressing the cutting valve will indeed blow the flame out. So a quick basic rundown, start with all of the valves turned off fully, there should be three valves on a combination cutting torch set-up, before attempting to light the torch, open the oxygen valve on the main torch barrel next to the acetylene valve fully. Next open the acetylene valve enough to light the torch and once it is lit open it additionally until the smokey soot just goes away and the flames are still attached to the end of the cutting tip. Now open the oxygen valve that is located on the cutting head assembly by itself until you achieve a neutral flame at the cutting tip, depress the cutting lever and adjust the oxygen additionally to achieve a neutral flame again while the cutting lever is depressed. If everything is working properly this should get you set to do some cutting and would indicate that there are no issues with this cutting assembly. On the other hand, if this cutting torch head is the type that is a dedicated cutting torch and only has an acetylene and oxygen valve, then I would agree with the other posters and you should probably take it to your local welding supplier and see about having it rebuilt. Just a few additional items for thought. Best regards, Allan
Elliot-
The bevel seats on the head need to be 'reseated'. You have cutting (center hole) oxygen seeping past the small bevel and into the outer holes, this is causing your flame to be blown out. If you don't have a repair center around you that can reseat the head, then try this.
Cut and secure a piece of fine grit sandpaper to the tip (grit side out), making sure it is as tight to the tip bevel as you can get it. Set it in the head and turn, turn, turn away. As you proceed with this process you will see the torch head bevels change (highlighting your highs and lows.)
