![](/mwf/attachments//avatars/19261-6136.jpg)
I'm saying this politely-- this is not advisable. Consider the circle of weld current you are creating, right back into the coils. (page B-2 of this Owners manual link advises this should not be done)
http://www.mylincolnelectric.com/Catalog/operatorsmanualdatasheet.aspx?p=33994"Connect the welder output studs to a suitable
resistive load bank. Note that any attempt to
short the output studs by connecting the welding
leads together, direct shorting of the output studs,
or connecting the output leads to a length of steel
will result in catastrophic damage to the generator
and voids the warranty."
Matt- you have a 23hp Kohler on your machine? Since its a new machine and you need to be standing next to it while you break it in (unless you have a load bank) grab a couple handfuls of rod, turn the machine to max and runs holes in a plate of steel for 1/2 hour to 45 mins.
