In the great majority of the time it is not recommended to preheat SS except to slightly heat it to remove the moisture. In exceptional cases where one is welding 2 different thicknesses, it might be recommended to heat the thicker material (stainless or carbon steel) slightly to insure a more even cooling rate.
