How thick are the majority of your workpieces going to be? Also,you cannot weld the aluminum without 1st removing the anodizing at least at the joint to be welded.Also,there is a different filler rod requiered to weld with if you are going to have parts anodized/or/re-anodized.This filler rod is requiered because the standard al. filler rod will come out a different color than the surrounding non-welded portions.Usually much darker has been my experience.The lincoln is a good machine and should be fine for most applications.Are you going to be doing production-runs? If so and you are welding on thick pcs, you may hit the duty cycle on AC ,but if your not continuously welding on ove 5/16" aluminum,you should be just fine.Gary,......
