Up Topic Welding Industry / Technical Discussions / trouble with .064 6061 tube
- - By vwjoegolf Date 04-08-2007 20:00
i am using a syncrowave 200 and i am trying to weld .064 wall 6061 aluminum tube.  the joint is a fishmouthed piece being welded at 90degrees to a longer length of tube both the same wall thickness.  No pulse on, 4043 wire 1/16, 1/16 pure tung., foot control around 60-70 amps, and 17cfm on the argon.  The problem is the puddle falls out and the and it is tough to get the puddle to be on both pieces of tube, thats not to say it is erratic it is just tough to get the arc so that the puddle form the "fillet" and by the time you do it is ready to burn through.??
Parent - - By 357max (***) Date 04-08-2007 20:39
Use a "Scotch Brite" pad and clean all weld surfaces inside & outside. Wipe w/acetone. Use a 3/64"/0.047 or smaller filler wire. Of course use "max penetration" on the squarewave ac balance control with a sharpened tungsten.
Parent - By Lawrence (*****) Date 04-08-2007 22:15
Max said it right.
Also
Jettison the Pure tungsten and go with the same diameter Ceriated or Zirconiated.
Water cooled torch?  I hope so.
