Up Topic Welding Industry / General Welding Discussion / recommendations for an amp volt meter
- - By hogan (****) Date 04-13-2007 16:58
my current amp volt meter decided to retire. i'm looking for the forums preference on these. what do you recommend and why?
Parent - By PhilThomas (**) Date 04-13-2007 23:37
I've found the Miller Digi-Meter to be as nice as any.  Digital, robust, and will hold an average of the first several readings (so you can set your own parameters) or give real time readout.  A bit pricey....but an excellent unit.
Parent - By makeithot (***) Date 04-14-2007 01:50
I use a fluke meter. Again a bit pricey $425.00 cdn , but does it all.
Parent - By 357max (***) Date 04-14-2007 15:33
Fluke with the digital display & hold function and the clamp on amp meter.
Parent - By Joseph P. Kane (****) Date 04-15-2007 17:33
ExTech makes a good digital unit with a data-logger attachment.  It costs in the $700.00 range.
Parent - - By billvanderhoof (****) Date 04-16-2007 04:02
I've got one from Radio Shack, digital, about 50 bucks if I remember right, does what I ask it to.  I envy you guys who can afford Fluke.
Bill
Parent - By scott harrison Date 04-16-2007 18:44
I am using a BK Precision, a little pricy, but very accurate and easy to use.
