Up Topic Welding Industry / General Welding Discussion / magneto not firing
- - By tompit9 (***) Date 05-03-2007 13:23
anyone with any help would be greatly appreciated. I have tested the coil being grounded and touching the mag. and coil. But not getting any fire out of the cap.
Is my mag. out of timing and if so how do I get it back in time?
THANKS A BUNCH
Parent - - By RonG (****) Date 05-03-2007 17:32
What gap? Did you check for residual magnetism? You will not see fire across the point gap. The Mag has an impulse spring that snaps the rotation to make it fire at the tab on the coil.
With No#1 cyl on TDC compression install the mag set to fire on No# 1 but on the compression side of the impulse.
Parent - - By tompit9 (***) Date 05-04-2007 06:45
propably a dumb quest. whats the TDC? I'm not really savy on engines, so I need to get the #1 cyl. on high and set the rotor to the #1 plug? I'm Igetting it or am I way off?
thanks
Parent - By RonG (****) Date 05-04-2007 21:13
Top Dead Center. Have you removed the the Mag from the engine?
Parent - By rwiegel Date 05-04-2007 04:00
Greetings fellow mag owner..try this link http://www.smokstak.com/forum/index.php
Mag and carb parts www.Bransonenterprises.com   - do a web search search..
Just got some carb parts from them for my sa200
Rick
