Up Topic Welding Industry / Technical Discussions / D17.1:2001 Question
- - By GaryC69Z Date 05-04-2007 12:30
In paragraph 4.2.3.2 Extended Validity. When this paragraph speaks of (uses a process) is this meaning in terms of GTAW, SMAW, SAW,... ect. or does this mean a particular weld schedule?
Parent - By Lawrence (*****) Date 05-04-2007 12:51
You had it right the first time... Continuity continues with verified work in process... GTAW, GMAW, whatever.
In house qualifications may be more strict or comprehensive but to comply with code you need only verify work in process.
