Up Topic Welding Industry / General Welding Discussion / Center of the pipe
- - By Komzt Date 06-30-2007 13:21
does anyone know were i can find a center of the vertical pipe?
formula, tool?
Parent - By G.S.Crisi (****) Date 06-30-2007 14:59
If I've understood correctly your question, you want to determine the centerline of a vertical pipe.
There's a tool called "universal square" that can be used to do that.
Among other manufacturers, Mitutoyo (www.mitutoyo.com) makes that tool.
Parent - By turbolaser (**) Date 06-30-2007 15:06
You have to be a little more specific about what you mean by "center of vertical pipe".  No idea if you mean the center of length, diameter, or centered off a reference point of another object or pipe running with or connected to it.  Please give some more details and I am sure we can answer your question.
Parent - By DaveBoyer (*****) Date 07-01-2007 02:29 Edited 07-02-2007 02:19
Formula for finding the center of a pipe: Outside diameter divided by 2. They don't call Me a wiseguy for nothing. The tool Mr. Crisi mentioned is often called [in the US] a "Center Head" and is used on the scale of a combination square.
Parent - - By Sourdough (****) Date 07-01-2007 19:02
center finder......yep, that's what it's called.
Parent - - By swnorris (****) Date 07-02-2007 13:07
Mine's made by Curv-O Mark
Parent - - By makeithot (***) Date 07-05-2007 14:43
I don't know if it is the same tool but , Pipe level is what I have always called it made by curv-O-mark.
Parent - By cmays (***) Date 07-06-2007 01:23
Curv-o-marc is what I use but Flange wizzard makes a good one as well. Their stuff is a little high but excellent tools.
