BAg-7 works. The color match should be good.
Bag-24 is stronger. Gold color.
Bag-22 is strongest but a bit harder to work with. Gold color.
This is from a brazing standpoint based on my experience. Can't help you from a medical standpoint. I Assume no liability, etc.
I believe all of those filler metals contain zinc and or cadmium, which I am assuming are bad news for implants. BAg-8 or BAg-13a are Cu/Ag or Cu/Ag/Ni fillers that might be ok, of those BAg-13a will work without a flux via vacuum brazing. Bau-4 (Au/Ni) or BNi-2 (Ni,Cr,Fe, B, Si) might be a better choice. I also do not know if any of these meet the Class 6 requirements, but they do work for brazing 304.
Justin Liguori
Scarrott Metallurgical
www.scarrott.com
