Up Topic Welding Industry / Technical Discussions / Impact value cal. Average or Total of all passes
- - By arpatel1985 Date 01-19-2008 07:29 Edited 01-19-2008 10:36
PASS    AMPERE  VOLTAGE   SPEED  HEAT INPUT
1  90  11    75  7920.00
2  120  14    90  11200.00
3  140  15    80  15750.00
5  100  12    100  7200.00
6  150  16    80  18000.00
01,02,03 one side passes
04,05 after backchipping passes
Now for 01,02,03 one side passes what will be heat input
             Average of 01,02,03           or     Total of 01,02,03
Parent - By 803056 (*****) Date 01-19-2008 13:38
I use an Excel spread sheet and the statistical analysis tool to determine the median, average, and standard deviation based on the parameters of each pass. The reported average is the average based on all the weld passes and I limit the range to one standard deviation unless it is beyond the range listed by the appropriate welding code or standard. I have never had that happen, but it is something to consider.
Some welding standards state that there can not be any variation exceeding X% for each pass, but that isn't a condition in all welding codes or standards.
Then there is the question of whether the referrenced code or standard requires two procedures, one with the high heat input and one at a low heat input to develop the allowable ranges of welding parameters. Every code has different requirements.
Parent - By weldgault (**) Date 01-19-2008 22:44
Volts X Amps X 60 Devided by Travel speed, will give you Joules of heat input.   John
