Up Topic Welding Industry / Inspection & Qualification / UT OR RT for corner joint welds
- - By kellie_paiche Date 01-26-2008 20:58
Hello Experts,
Please share ur thoughts- Is UT or RT recommended for corner joint welds and why?
In terms of corner joint welds, why is one method beter than the other?
thanks
Parent - - By CWI555 (*****) Date 01-26-2008 23:12
butting members or non butting members, full pen or not full pen. Which is your flavor?
Parent - - By kellie_paiche Date 01-30-2008 01:22
full penetration............corner welds for box headers in air cooled heat exchangers.........
Parent - - By CWI555 (*****) Date 01-30-2008 06:57
I would go with UT. If for no other reason than film placement problems
Parent - - By thirdeye (***) Date 01-30-2008 16:39
I would have to agree.  About 10 years ago one of my clients built the same type header boxes that were about 15" X 20" X 1" thick.  RT was required by the engineering folks, they would not allow UT.  From what I recall not only film placement, but distortion and projection of the root area was a problem on the closure joint.
~thirdeye~
Parent - - By CWI555 (*****) Date 01-30-2008 18:23
"distortion and projection of the root area was a problem on the closure joint"
That sounds about right
Gerald
Parent - - By maxilimiano (**) Date 01-31-2008 04:05
I think UT (all configuration T K Y) is best way to inspect.
Parent - - By CWI555 (*****) Date 01-31-2008 04:23
It usually is.
Parent - - By jmdugan10 (*) Date 02-01-2008 16:27
The only thing you will get with RT is an information only shot.  The shot most likely will not meet the geometric unsharpness requirments.  You'll see everything if you get proper film placment but the measurment of indications will be off.  Any indication will be magnified beyond the Ug.
Parent - - By hogan (****) Date 02-01-2008 17:16
i think i would be more concerned with getting complete coverage when performing rt on a corner joint.
Parent - By CWI555 (*****) Date 02-01-2008 21:15
I would agree with that
- By Sambuddha (*) Date 02-03-2024 09:48
As per UW 12,Type 7 Joint i.e. Corner Joint RT or UT is not possible.
Now if we try to do UT what will % of defect can be revealed.
