Up Topic American Welding Society Services / Certifications / Deformed Bar
- - By Leadburner Date 03-06-2008 20:53
Can anyone tell me the AWS code for bending deformed bar.  I've got A 496 but it says nothing about bending and stresses.
Parent - - By 803056 (*****) Date 03-06-2008 20:59
AWS only addresses welding rebar, not fabricating rebar.
Parent - - By Leadburner Date 03-06-2008 21:29
Hey, I found it!
D1.1 Structural Welding Code 7.6.6.1
The bar can be bent 90 degrees from it's original axis over a pin that is
4 times it's dia.
Parent - By hogan (****) Date 03-06-2008 22:25
if your sure
Parent - By MBSims (****) Date 03-06-2008 23:19
You lost me on that one.  7.6.6.1 addresses bend testing of studs, not deformed bars.
Parent - - By johnnyh (***) Date 03-06-2008 23:28
Slow your roll......get it?
Parent - By swnorris (****) Date 03-07-2008 14:54
A496 Minimum bend diameters:
DBA dia.      Min. bend dia.
1/2"                   3"
5/8"                   3 3/4"
3/4"                   4 1/2"
7/8"                   5 1/4"
1"                      6"
DBA's should always be bent before welding.  The weld should not be closer than two times the DBA diameter from the bend.
