Up Topic Welding Industry / Technical Discussions / Welding 6061-T6 to Cast Aluminum 356-T651
- - By Phil26J Date 04-01-2008 19:26
I am looking at a job the requires the welding of 6061-T6 aluminum to cast aluminum 356-T651. There is no requirement to keep the T6 condition after welding so is TIG welding with 4043 weld wire the best bet?
Parent - - By Lawrence (*****) Date 04-01-2008 20:51
Welcome to the Forum Phil
4043 is the primary choice according to the Aluminum Association
They footnote that 5356 may be an alternate choice if you are annodizing and looking for a better color match and better ductility.
Parent - By Phil26J Date 04-02-2008 13:55
Thanks for the confirmation. I had an older AWS book that said 5356 would work with 4043 in the footnotes.
