Up Topic Welding Industry / Technical Discussions / 304 stainless steel to titanium
- - By weldr61 (*) Date 06-21-2008 00:25
Is it possible to weld 304 stainless steel to titanium? And if so what process would be used and what filler metal would be used?
Thanks
Chas. Miller
Parent - - By Lawrence (*****) Date 06-21-2008 03:36
Chas,
Welcome to the forum!
It's not going to happen with any of the big 4 processes.
I don't even think an EB would do it.
Maybe a vaccume braze?
Maybe something wierd like explosion welding..
Parent - - By ssbn727 (*****) Date 06-21-2008 06:13
Friction Stir process anyone???
Perhaps a specially modified laser system could do the job also but, without any further specifications or details, it's going to be improbable for you to get a specific answer that will suit your particular needs. :) :) :)
Parent - By Plasma-Brain (**) Date 06-23-2008 20:49
I admit I know little about how the process really operates, but would ultrasonic welding work?
Adding about 1/2 a cents worth...
-Clif
Parent - - By GRoberts (***) Date 06-23-2008 06:08
where a bond is needed, explosion welding can be used.  Components can be machined out of the bonded plate, and then subsequently welded to like components for a transition joint.  If you are asking if the two can be arc-welded together, then that would be a "no".
Parent - - By js55 (*****) Date 06-23-2008 13:33
Perhaps a root pass of 50% Ti, 35% Fe, 10% Cr, 6% Ni, C in the ppt's and not the ppm's, might call it beta crackalloy.
You'd wanna call a minerologist to do the analysis because I'm guessin that stuff is gonna be a rock.
Parent - By weldr61 (*) Date 06-24-2008 02:17
Thank you, to all who replied. It confirmed pretty much what I had expected.
Thanks again,
Chas. Miller
