I've gone ahead and finalized the welding cost estimator, I've included cost per hour which is probably more useful to some. Input variables are in blue, you know the drill. I'm also including at no extra charge a welded joint strength calculator, fast way to get joint stregnth as Per ASD. I checked the figures to a table I have and everything came out exactly the same for the base calculations.
I'll make it known that there's lots of caveats for weld design and you still have to calculate how much force is on the weld but this is a good way to quickly ball park two welds to see the strength and it will output numbers that match the AWS ASD tables. My last project is tying it all together so that you can input the weld size and get the strength and then figure out how much metal and how long it would take to weld.
Anyways here's a list of things it does in case people ever want to search for it
Calculate fillet weld strength
calculate sheet metal strength
Calculate groove weld strength
calculate welding cost
calculate travel rate
Consumables cost
calculate heat input, joules per inch
