![](/mwf/attachments//avatars/95-7168.png)
If I am understanding you question the answer would be yes providing you have a GTAW torch and Argon gas w/regulator.
The power source for SMAW & GTAW are the same. If the machine does not have a pin connection for a remote you can still work you just need a on/off switch on the torch, you will just need to have some one near to help tune in your heat do a lot of starting and stoping to set you Amps.
Also unless the machine has a switch between Start only / Constant for the high freg you will need to scratch start.
