Hello,
Can anybody help me to butt-weld aluminium pipes?
Theses pipes are 100 mm dia.and 8 mm wall thickness.
Welded joint should be 100% x-ray quality as these pipes will be used as busducts for tranmission of high current from power generator to main transformer.
joint prep. is single- V, 70 deg., 2 mm land and root gap of 1.2 mm
Planning to use Pulsed-MIG process. Can any expert suggest suitable process,machine,welding parameters for this job?
