Up Topic American Welding Society Services / Technical Standards & Publications / Weld layer width allowable
- - By Bill M (***) Date 09-30-2008 12:31
Ref:  AWS D1.1 table 3.7 (prequalified WPS requirements)
Does the "maximum single pass layer width" row at the bottom of the table apply to both butt welds and multi-pass fillet welds?
Parent - - By swsweld (****) Date 09-30-2008 16:03
Bill, I think the multi pass fillet would contradict the single pass layer intentions.
Parent - - By flamin (**) Date 09-30-2008 16:09
Also, the multi pass fillet would need to be qualified under Section 4 Part B (4.11.2). I don't believe it is prequalified.
Jason
Parent - - By ctacker (****) Date 09-30-2008 16:45
Why do you say A multipass fillet needs to be qualified?
If you look at table 3.7  max. electrode diameter for flat fillet, using SMAW is 5/16" EXCEPT root passes which is 3/16"
so how could you use 5/16 rod without having a root pass using 3/16" or smaller electrode?
Parent - - By flamin (**) Date 09-30-2008 16:51
I stand corrected.
Jason
Parent - - By Bill M (***) Date 09-30-2008 17:20
So what is the max weld layer width for multi-pass fillet welds?  Can a flat 1-1/2" fillet weld be covered with a single pass for example?
Parent - - By motgar (**) Date 09-30-2008 18:46
Bill,
I would say no, based on the weld type column stating, any layer of width.
The only two situations that come close would be multiple electrode SAW, or note e for GMAW/FCAW.  Both of these state: if width exceeds one inch then to split layers.
Parent - By Bill M (***) Date 09-30-2008 20:25
I agree, but then what is the max single pass layer width limit for a mult-pass fillet weld on plate using FCAW in the horizontal position?  Do you have to split layers when over 5/8" wide, or is that just for a butt weld?  (table 3.7 note 'e')
A single pass FCAW 1/2" fillet weld is acceptable with a face width of 0.71".
