Up Topic American Welding Society Services / Certifications / ASME question
- - By ctacker (****) Date 10-12-2008 05:22
I need to weld 316L(P8) to A285(P1)  I have a procedure for A36(P1) to A240(P8) using E309-16(F5) Rod. Can I use the same procedure. ? (I think I can but need some reassurance)
Also for qualifying welders (SMAW) can I test with A P1 plate (A36) and a F5 rod (E309-16) ?
Or what would be used for qualifying?
This is the first time for combining base metals using ASME so I'm a little unsure of how to go about it. Any help would be appreciated.
Parent - - By dlmann (**) Date 10-12-2008 11:50
Looking at ASME QW-253 and QW-253.1 your existing SMAW WPS for P1 to P8 using a F5 covered electrode will serve your stated purpose.  No requalification of your WPS is necessary.
Your WPS allows you to use P1 material with F5 covered electrode for welder qualification.  This will qualify them for P1 and P8 material, ref QW-423.1
Your customer may want a WPS that clearly specifies the material being welded, you example 316L(P8) to A285(P1).  In this case you just develop a new WPS for your customer from your existing PQR.
Regards, Donnie Mann
Parent - By ctacker (****) Date 10-12-2008 20:32
Thats the way I understood it. I'm not real familiar with ASME though. I wanted to be sure I wasn't missing anything.
Thank you,
Regards, Carl
Parent - - By ctacker (****) Date 10-14-2008 18:19
Ok, Let me see if I got this right,(this is different than previous post btw) welder qual. essential variables. SMAW.
I need to qualify welders to weld P43(Ni-Cr-FE tube) to a P4 (ASTM A217 WC6) using SFA 5.11  E8N12 (ENiCrFe-3, F43)
Looking at QW-353 (Base metals QW-403.18) I can substitute QW-423 in its place?, and use A P1 plate for testing?
and QW-404.15 Filler metals I need to use an F43 filler? (or use QW-433 and use F34 or any F41 thru F45 filler).
Thanks in advance!
Carl
Parent - - By pipewelder_1999 (****) Date 10-14-2008 18:39
You are correct. You can qualify for Nickel Alloy SMAW using F43 Filler and P-1 base material.
Parent - - By ctacker (****) Date 10-14-2008 18:41
Thanks, I'm starting to think ASME is a little easier to understand than D1.1
Regards, Carl
Parent - By js55 (*****) Date 10-14-2008 19:13
Its older and wiser in many ways. But we won't mention Section VIII or impact testing under 31.3.  :)
Parent - - By motgar (**) Date 10-14-2008 20:47
Was the original PQR, the one with A240 to A36, done with approved ASME materials.  Meaning the specification of the material.  Were they SA-36(P1) and SA-240 Type......? (P8)?  If they were ASTM A-36(S-1), and A-240 Type.........?(S-8), then you might want to look at QW-420.2 S-Numbers.
The third paragraph states:  If the original PQR materials were assigned S-numbers or S-number Group number, then the range quailified is limited to S-number and S-number Group numbers.  (i.e., qualification using P-Number material qualifies corrosponding S-number materials; qualification using an S-number material quailifies corrosponding S-number materials but, not corrosponding P-number materials)
Parent - By ctacker (****) Date 10-14-2008 21:38
Our server has been down for the last 2 days, But my spreadsheet printout lists ASTM A36 to ASTM 240. I'll have to look when they come online.
Thanks for pointing that out!
Carl
