Up Topic Welding Industry / General Welding Discussion / Grasshopper
- - By shawn2828 Date 12-23-2008 22:18
how do i build a grasshopper?
Parent - By OBrien (***) Date 12-23-2008 22:21
If were talking about the same thing just put a ground clamp on each end of a length of lead.  But everyone has their own termonaligy.
Parent - - By KSellon (****) Date 12-23-2008 22:50
hope this helps-- Hopefully Ross can make it smaller
Parent - - By Tamper (**) Date 12-24-2008 01:18 Edited 12-24-2008 01:42
Ok this is gonna be dumb but, what is that for? Just to connect two leads together? Because around here a grasshopper is a c-clamp that is cut off and you weld it to the metal to push/pul the metal to align it.
Parent - By Milton Gravitt (***) Date 12-24-2008 15:39
Tamper,I have always thought the cut of c-clamp was called a thumbelina.
                           MG
Parent - By ZCat (***) Date 12-24-2008 16:27
They use a grasshopper on pipelines for the ground when you can't get to the end of the pipe to put your ground clamp on. You put the grasshopper so that it grounds in the bevel or on the weld.
Parent - By jrw159 (*****) Date 12-24-2008 02:32
Shawn,
  You can build one in many differant ways. Immagination is your only limitation. Kaye gives a good basic diagram. Here is a link to a pic from another thread concerning this.
http://www.aws.org/cgi-bin/mwf/topic_show.pl?pid=85454;hl=grasshopper
You can also use the search feature and come up with some more info on differant styles and preferances.
jrw159
Parent - By shawn2828 Date 12-24-2008 03:03
thanks yall for your help
