Up Topic Welding Industry / General Welding Discussion / Brazing radiator
- - By djm1987 (**) Date 01-04-2009 23:04
My buddy has a pinhole leak right on top of his radiator. I havent brazed for years. What would u all suggest for this repair. Very , very small hole. needle size. Brazing it with torch and brazing rod best? Thanks
Parent - By gshuma (**) Date 01-05-2009 00:22
Almost every radiator that I have seen has been soldered at assembly. If you put enough heat on it to braze you will probable melt some nearby joints.
I have fixed a few old car radiators with a Weller soldering gun or a soldering copper.
It has to be clean to be successful and that's the hard part.
Good luck
