Up Topic Welding Industry / Inspection & Qualification / examples of weld profiles
- - By hogan (****) Date 01-07-2009 18:10
Anyone have any examples of weld profiles? drawing or pics. I'm looking for a little more than is provided in AWS D1.1 figure 5.4(08). Thanks for any help.
Parent - - By 803056 (*****) Date 01-08-2009 05:04
There are several pieces of literature available from AWS that addresses the visual aspects of weld inspection and discontinuities. You might take a look at the two guides available from AWS. Guide to NDT of Welds (B1.10) and Guide to Visual Inspection of Welds (B1.11) would be a good starting point. Both guides are in the process of being revised.
You should be able to borrow them from your AWS Section library if you are an AWS member.
Parent - By hogan (****) Date 01-08-2009 14:18
Thanks
