Up Topic Welding Industry / Welding Fundamentals / Dogs, not the woof woof kind
- - By TozziWelding (**) Date 02-15-2009 14:11
Just an old trick that I made new again yesterday.
[IMG]http://i94.photobucket.com/albums/l110/TozziWelding/WorkStuff043-1.jpg[/IMG]
[IMG]http://i94.photobucket.com/albums/l110/TozziWelding/WorkStuff038-1.jpg[/IMG]
[IMG]http://i94.photobucket.com/albums/l110/TozziWelding/WorkStuff039-1.jpg[/IMG]
[IMG]http://i94.photobucket.com/albums/l110/TozziWelding/WorkStuff045.jpg[/IMG]
Parent - By gndchuck (**) Date 02-15-2009 16:34
ah screw dogs, haven't made any of those in a couple of years.  we use them for holding pieces to the rig when welding underwater, then again we use hydraulic impacts for tightening them.
Charles
Parent - By burleigh26 (**) Date 02-16-2009 00:54
dogs are a life saver.  i use them when doing inserts on boats.  i have a few different types i made.
Parent - By raftergwelding (*****) Date 02-17-2009 17:33
i've made some lshaped dogs to get closer to the wall on a mud tank i use to keep them on the truck but lost them in time they sure help alot i've also made some to use with wedges
Parent - - By 357max (***) Date 02-17-2009 19:26
When I made dogs I would weld the nuts first and then when cold I would thread chase. Seems the nuts have a habit of shrinking after welding. Either use a grease like anti-spatter or plain grease on the threads to keep them clean. Another way to build dogs; that is a bit more expensive, is use all position hydraulic "bottle" jacks instead of the nut and bolt. thanx for sharing the photos.
Parent - - By Superflux (****) Date 02-17-2009 20:44
I've found that by placing the corner of the nut instead of the Flat against the dog and welding, I don't have to chase threads. Have the bolt screwed in, smoke some acetylene (anti-spatter soot!) on the threads, weld them up.
A bit tougher to fit-up but it works!
Parent - - By TozziWelding (**) Date 02-17-2009 21:52
Those are 1" A325 structural bolts, I ain't worried about the threads.
Parent - - By Stringer (***) Date 02-28-2009 05:14
Looking at your clamps I just realized how wore out the threads are on all my clamps!
Parent - By Bob Garner (***) Date 03-02-2009 21:35
We get all these warnings about welding high strength nuts due to their heat sensitivity.  Anyone ever have one of these welded nuts crack?  This seems like a real test of the "rubber meeting the road", and I wonder how much we have to fear welding on nuts.
Bob G.
