Up Topic Welding Industry / Technical Discussions / Welder test and welder certificate
- - By TolgaKantaroglu (*) Date 02-07-2002 20:31
Is there any specification concerning the welder (operator) test of Submerged Arc Welding process? Or this method (since it is automatic) is only qualified for Welding Procedure Specification.
Parent - By RonG (****) Date 02-08-2002 12:55
SubArc is Simi-automatic (like GMAW and FCAW) and qualification is the same as with all Processes.
Just because a person is qualified for a manual process such as SMAW or GTAW does not qualify them for SAW or any other process other than the ones they are qualified in.
There are other Esential Variables that discribe the ranges of qualifaction in a process.
Parent - - By Niekie3 (***) Date 02-08-2002 22:45
If you look at a code such as ASME IX, it will give you all the performance variables for each process, including SAW.
Niekie
Parent - By TolgaKantaroglu (*) Date 02-10-2002 00:32
Thanks for your kind help and interest.
Regards.
