Up Topic Welding Industry / General Welding Discussion / Band type pipe beveler.
- - By emccorma Date 06-10-2009 01:52
Hey guys, I have to cut and bevel 8" sch40 steel pipe , the problem is my space is very limited probably 5-6". I have seen the band type beveler's with a torch that runs parallel the pipe you are cutting and you adj. the angle of the cut with the torch head. Has anyone else seen this and if so do you know the manufacturer. Thanks Ed
Parent - By B.acosta (**) Date 06-10-2009 03:55
mathey makes them
Parent - By TRC (***) Date 06-10-2009 21:21
The minimun distance for the mathey is 7". Also the 6 & 8" bands are for slide over the end of the pipe only. If you spread them to go over the pipe they will deform and cause major problems. Ted
