Up Topic American Welding Society Services / Technical Standards & Publications / Fabrication
- - By Nalla (***) Date 10-04-2009 13:03
Dear Friends
During sub-assmebly stage it was noted that Main Girder Frame Web Plate exactly sitting on Butt-Joint of adjoining Face Plate( width 700mm x 32mm thk x EH36 ).
Then Reinforement was gring flush floowed by UT/MPI and found acceptable.Then Main Girder Frame installed - PJP Joint. Is it right thing to do ?
Thanks in advance
Parent - By CHGuilford (****) Date 10-06-2009 16:21
I don't have a clear understanding of what you are dealing with.  However, you do not feel good about something you are seeing.
Is it possible for you to check with the responsible engineer?
