Up Topic Welding Industry / General Welding Discussion / 7018 DCEN?
- - By weldhawk71 (**) Date 11-19-2009 01:48
I'm being told to run 7018 dcen on 3/8 plate vertical up. Does this make sense to anyone?????
Parent - By strother (***) Date 11-19-2009 01:55
No
Parent - - By KFab (**) Date 11-19-2009 02:11
generally no  with some exception, say lincoln has a 7018ac rod that can be run in both polarity's,  i let people think there right all time.. it works at home and on the job site :P
Parent - - By Master0428 Date 11-22-2009 22:51
  ive ran 7018 on DCEN just to see what would happen, the result was an arc that was bright green with a spattering noise, it was kinda fun but i would not advise it on the job lol.
Parent - By Superflux (****) Date 11-23-2009 00:06 Edited 11-23-2009 00:08
weldhawk71,
The following was cut and copied from Lincoln's website and DCEN is NOT listed for polarity options. (FWIW, none of their other xx18-xx were of DCEN either)
Excalibur 7018 MR E7018 H4R AC, DC+ There’s a long list of reasons why operators are so loyal to Excalibur 7018 MR. They tell us they love the clean puddle, the square coating burnoff, the easy all-position handling and the excellent wash-in characteristics. It’s a terrific choice for jobs that involve steels with poor weldability.
Excalibur 7018-1 MR E7018-1 H4R AC, DC+ When the job involves critical, out-of-position welding, reach for Lincoln Electric’s Excalibur 7018-1 MR. It offers a beautifully clean weld puddle, uniform slag follow, and superior wash-in with no undercutting. Also great for welding on steels with marginal weldability.
Lincoln 7018 AC E7018 H8 AC, DC+ AC? DC? This electrode performs beautifully either way! Lincoln 7018AC is a great choice for low open circuit voltage AC power sources. Cold restrikes are no problem with this versatile, all-position electrode.
What circumstances led up to this suggestion?
Sometimes knowing the WHY is more interesting than the answer(s)!
Parent - - By north_fl_cwi (*) Date 11-23-2009 19:38
I think you will find a lot of people do not know the difference between straight/reverse and dcen/dcep.  Ask for a copy of the welding procedure. :)
Parent - - By makeithot (***) Date 11-27-2009 18:21
It is sad to think, that if you work in this industry and you don't know the difference between dcen, dcep, striaght and reverse polarity being that it is first year material.
Parent - By north_fl_cwi (*) Date 11-30-2009 13:01
I agree, but ask around, I think you will be surprised.
