Not suggesting replacement of personnel by software. The point is SOMEONE KNOWLEDGEABLE has to deal with the welding documentation. Usually, that SOMEONE is paid more per hour than can be justified to perform basic filing and tracking functions. The whole point of using software is to help people automate and speed up repetitive and time consuming tasks. Yes you could build a car by hand without investing in automation. But, would you be saving any money?
Now, put yourself in client's shoes for a moment and ask yourself: Would I prefer my consultant (or subcontractor) use the latest tools? Or would I rather be told that my work is being done "by hand"?
Autocad did not get rid of the need for draftsmen or designers and accounting software did not get rid of accountants. But do you know of any draftsman, designers or accountants still in business today who do not use specialized software?
Calculating return on investment is a reliable method by which you can easily justify the price tag of anything. Just use the time spent on documentation multiplied by the salary rate. Any serious code weld shop will quickly see that it is loosing money by not using the software. Doing a little bit of math should also show that the welding lenses and paint markers could also be affordable.
Have a nice and a good day.
At some point automation does provide a return. It may take a while with a fabricator/erector with 10 WPS's and 30 welders. Tracking that type of documentation is not a moumental task. I could build a go-cart with automation, but would I be saving any money?
I worked a piping job one time where the entire plant was modeled in 3d. I was given nice computer generated ISO's and told to run the pipe. I calculated the dimensions given on the ISO's with my little HP32 calulator, plumb bob and water level an behold, a 6" pipe was running through a 14" beam. The foreman who couldn't even use my calculator indicated he could show me on the "Model" where the piping went. We went to the computer and there was the pipe running through the beam. This was not what was intended and the piping was re-routed. It was done by hand.
Specialized software has a place but many of the functions of software are rigid. If you learn how to utilize a computer fully, many of the things that are done by specialized software can be performed with off the shelf applications that have much more versatility.
I agree that it is very useful. It just may not be for everyone. I ordered a trial version today and am looking forward to checking it out.
I hope everyone isn't getting tired of this but I have enjoyed the discussion and have re thought some of my positions.
Have a good day.
G Austin
I guess "Louis" should tell us whether he's making go-carts or chevys?
Likewise, enjoyed the discussion. Have a productive day. stan
I have played with my "welderqual" program a little and I'm very impressed. It is a very efficient visual basic application with microsoft access table's.
I would highly recomend it for anyone with the money to spend.
G. Austin
