Forum Members,
I would appreciate opinions on this weld failure I suspect under bead cracking do to possible insufficient preheat or preheat being skipped. There also appears to be an area where lack of fusion to the A36 flange occurred.
Welding Information:
AWS D14.3:2005
2” SAE-1045CFR to A36 shot blasted
Preheat 200°F per WPS (not verified by me at time of welding) probably should be 325°F
GMAW
ER70S-6
Gas M5 95/5
.25” Fillet
26V per WPS (not verified by me at time of welding)
375 IPM Wire Speed per WPS (not verified by me)
Thanks,
Rey
SAE 1045 is a medium carbon steel (carbon content 0.45 %) and can not be welded like low carbon steel (carbon content 0.25 % max.). Preheat is mandatory. If it wasn't done, good chances are that the weld is unsatisfactory.
Giovanni,
My office is in Quality Control at the company’s main manufacturing plant and I suspect that at the manufacturing plant that these components were made the WPS was not followed. I was looking for opinions if this is a typical type of failure when preheat was not performed.
Thanks,
Rey
This type of fracture is consistent with fractures I have observed in welded 1045 soil anchors with A36 flutes. However, to confirm underbead cracking, you will need metallographic examination of cross sections of the weld. This should include microhardness traverse at 0.010" spacing across the weld and HAZ to the unaffected base metal. Scanning electron microscopy of the fracture surface is also helpful in differentiating intergranular features of underbead cracking from the dimpled appearance of ductile overload. Locate a good local metallurgical testing lab for these services.
Also, a 1/4" fillet seems a bit small considering the size of the shaft and hub.
Thanks for the reply; unfortunately the company does not have what is needed to perform a metallographic examination and the microhardness test. I would have to find someone or a lab to do this and the fillet does seem to be a bit small
Rey
I am not sure what I am looking at in these pictures.
Is that a blind hole in the flange? It LOOKS like a fractured section of the shaft in that hole, and the end of the shaft sort of looks that way too.
Was that shaft a press fit in the hole before welding?
Is that .25" fillet on 1 side of the flange, or both?
How much load is on this part in service?
I would expect a higher pre heat [BOTH PARTS] and possibly post weld heat treatment due to the carbon content of the shaft.
It looks like it ran quite a while after the weld fractured.
Dave,
The shaft does have a turned section that is inserted thru the flange, so yes there is welds on the shaft on both sides of flange but it is not a pressed fit. There is a PDF drawing before the photos and I added an exploded view. The total amount of load I do not know, all I can say is it is an idler stub shaft on a conveyor. Also the shaft its self did break on the other side of flange at about even with that weld.
Thanks,
Rey
I would use a shaft material that lends itself better to welding, and follow the appropriate weld procedure. Also, I would increase the fillet size to minimum 1/2 the flange thickness each side.
The HAZ from the weld is likely responsible for initiating the shaft fracture.
Agree, and with the combination of such a small fillet and 70S-6 wire...IMO 80S would have been better here. Overengineered and underwelded. :)
bozaktwo1,
The fillet weld size detailed is marginal and the 80S wire would be closer to the tensile strength of the base metal. I put an ECR in to change size of weld and preheat but the 80S change will probably be rejected.
Thanks,
Rey
Looks like a preheat issue to me.
I don't see any failure in the weld except as you stated, it appears to have LOF to the flange at what is likely the weld start. If I am reading the pictures right, it looks like the ER70S-6 weld pulled base metal out of the 1045 shaft all the way around.
Blaster,
That is correct there is base metal gone all away around also the shaft failed at about where the weld is on the other side of flange.
Thanks,
Rey
