Up Topic Welding Industry / Metallurgy / Residual Stress
- - By mohsen roshani (*) Date 05-04-2010 21:37
Hello
i want to weld 2 sheets of ultrafine grained aluminium (produced by ARB process) by cold roll bonding and test the residual stress in the weld zone.
can you help me about the ways of measure the residual stress (except XRD) ?
can anyone help me about the ABACUS software ?
thanks
Parent - - By G.S.Crisi (****) Date 05-05-2010 00:13
The only way I know to measure residual stress is by X ray difractometry. Is there any other?
Is Abacus software used to measure residual stress after welding? If so, I'd also wish to know about it.
Parent - By ssbn727 (*****) Date 05-05-2010 09:09 Edited 05-05-2010 09:26
Hi Giovanni!
Here are some other methods used to measure residual stresses:
http://www.shotpeener.com/library/pdf/2008016.pdf
Here's another paper covering the UT method of residual stress measurement:
http://www.itlinc.com/pdf/33_Paper_on_UCC.pdf
These folks are pretty good at measuring residual stresses using primarily X-ray diffraction, but mechanical methods as well:
http://www.lambdatechs.com/laboratory-services/residual-stress.html
Here's one of their other methods  of measuring residual stresses using a Ring Core mechanical method as opposed to XRD:
http://www.lambdatechs.com/html/resources/dn31.pdf
This is from the Los Alamos National Lab:
http://www.lanl.gov/contour/
http://www.lanl.gov/residual/
Here's another interesting paper which describe a mechanical method used to measure residual stresses in weld overlay pipe:
http://www.iasmirt.org/SMiRT12/F03-3.pdf
This paper describes the use of a combination of XRD (X-Ray Diffraction) and mechanical  (strain gage) techniques in order to measure residual stresses resulting from the fabrication process of Alloy 600 nozzle and heater sleeve mock-ups:
http://www.lambda-research.com/html/resources/212.pdf
Another good article:
http://www.scribd.com/doc/6067883/New-Technique-for-Residual-Stress-Measurement-NDT
Here is another interesting method of measuring residual stresses:
http://www.ndt.net/article/v04n08/wojtas/wojtas.htm
Another interesting paper on measuring Residual stresses in thick Q&T steels:
http://www.iaeng.org/publication/WCE2009/WCE2009_pp1526-1531.pdf
Here's one of my favorites:
http://www.imeko2009.it.pt/Papers/FP_11.pdf
And finally this paper:
http://www.osti.gov/bridge/purl.cover.jsp;jsessionid=9D0F401D2E8CBD3171169E896620ACD8?purl=/481857-lyCpSD/webviewable/
Edit: I almost forgot these three papers:
http://hal.archives-ouvertes.fr/docs/00/25/41/50/PDF/ajp-jp4199606C118.pdf
http://www.aps.anl.gov/Science/Reports/1999/watkinst1.pdf
http://www.itlinc.com/pdf/35%20Info%20on%20RSM%20%28UP-UM-ES%29.pdf
And how could I forget this from Colorado State University:
http://www1.chm.colostate.edu/Files/Residualstress.pdf
Or this one authored by one of your very own countrymen Giovanni:
http://www.ipme.ru/e-journals/RAMS/no_22009/monin2.pdf
Enjoy the reading!!! :) :) :)
Parent - By ssbn727 (*****) Date 05-05-2010 08:23 Edited 05-05-2010 09:30
Here you go Moshen...
http://imechanica.org/files/1-2%20Learning%20ABAQUS.pdf
Here's a forum where you can ask specific questions regarding the ABAQUS software ,and there are some folks who may be able to help you out:
http://imechanica.org/node/365
Here's an interesting paper which just happens to originate from your country Giovanni:
http://www.lajss.org/index.php/LAJSS/article/viewFile/210/172
And here is another one from the same authors:
http://www.lajss.org/index.php/LAJSS/article/viewFile/176/205
Here's another interesting paper also:
http://www.tc.faa.gov/its/worldpac/techrpt/ar0756v3.pdf
You might want to get in touch with these folks also:
http://www.tracglobal.com/analysis-software-used.html
Here's another link describing their FEA stress analysis capabilities:
http://www.tracglobal.com/analysis.html
Here's another article:
http://lib.physcon.ru/download/p1664.pdf
These .pdf's may also be useful:
http://www.pdfgeni.com/book/Abaqus-2D-pdf.html
Another very interesting paper:
http://www.mar.ist.utl.pt/jgordo/Artigos%20Oficiais/3.3.11%20-%20ISSC2000_III.1_Ultimate%20Strenght.pdf
And finally this one also:
http://www.fe-net.org/downloads/FENet_Meetings/St_Julians_Malta_May_2005/fenet_malta_may2005_marine.pdf
Edit: How could I forget this paper:
http://www.mne.psu.edu/michaleris/Pubs/girthpvp96t.pdf
Parent - - By madibaa (*) Date 05-06-2010 04:31
aqaye roshani, hal mikoni ba henry?
Parent - By m.rostami (*) Date 05-11-2010 19:05
salam
baba ajab ojoobeiye in henry
daste ma ro ham begir o b in rafighet moarefi kon
