Up Topic Welding Industry / General Welding Discussion / Boom Test Via Boom Too Far!
- - By Northweldor (***) Date 09-15-2010 01:19
http://www.edmontonjournal.com/Gallery+Truck+goes+airborne+Calgary+mishap/3523231/story.html
This one passed! The operator.....????
Parent - By DaveBoyer (*****) Date 09-16-2010 02:15
Just because the boom is 180 feet long doesn't mean you can stick it out the side unsupported 180 feet, I guess.
Parent - By cmays (***) Date 09-17-2010 11:29
Seems like someone missfigured the possible weight of concrete filling 180 foot of line. You would think there would be some more redundancy (ie. dumb *ss operators) build into that machine.
- - By grizzzly (**) Date 09-15-2010 02:47
look at the last picture
i dont see why it is still in the air
Parent - - By Northweldor (***) Date 09-15-2010 12:38
I think the weight of the boom is using the dumpster next to the truck as a fulcrum.
Parent - - By Northweldor (***) Date 09-15-2010 12:43
Or, the support legs of the truck are serving as the fulcrum.
Parent - - By jwright650 (*****) Date 09-15-2010 12:53
Yup, I think it is the outriggers on the truck that pivoted the truck up into the air.
Is it just the picture or is the center boom section bent?(in the last picture)
Parent - - By Northweldor (***) Date 09-15-2010 17:18
It's hard to tell from the perspective, but I think the center section is still 4-5 ft. off the floor-level of the excavation, judging by the column rebar showing underneath.
This happened about 1:30 a.m. , several hours before daylight.
Parent - By CK Welding (**) Date 09-17-2010 02:49
boom in!  BOOM IN!!!  To late!
Parent - - By grizzzly (**) Date 09-18-2010 04:38
Ok I don’t know too much about these trucks but I thought that they were designed to be able to pump concrete with the boom sticking straight out like it is in the picture
It looks like he had already pumped some concrete so it was working for awhile?
The truck looks like it has a 5 section boom and there is two sections look like they are laying on the ground.
this just looks strange to me
Parent - - By Northweldor (***) Date 09-18-2010 11:22
Still no official news of the cause, but it could have been simple miscalculation of the weight of the concrete in the extended boom, or miscalculation of outrigger extension. Either could have caused a slow lifting of the truck as soon as enough concrete was pumped out.
Parent - By rcwelding (***) Date 09-18-2010 16:45
I saw one almost go over when the ground sunk about 8in... The timbers they had under the outriggers cracked and that pump truck started rocking.. It was a little scary... It didn't go over though... I saw the same thing happen with a 60 ton crane too...!!!
  RC
