Up Topic Welding Industry / General Welding Discussion / 7028 Question
- - By kcd616 (***) Date 10-10-2010 18:36
Anybody still using 7028 in the shop or has it finally been fazed out by MIG and FCMAW.
Sincerely,
Kent
Parent - By G.S.Crisi (****) Date 10-13-2010 20:32
Good question. I'm also curious to see what someone will answer to it.
Parent - By welderbrent (*****) Date 10-15-2010 04:01
I'm mostly with Wade.  If I want a low hydrogen electrode I use the XX18's.
While I prefer 7024 over 7028 it is not a low hydrogen and can't be used in many applications.
And in the shop, as well as when appropriate with winds and other factors here in AZ, I will take a wire feed anyday.
Have a Great Day,  Brent
Parent - By dbigkahunna (****) Date 10-15-2010 11:33
I don't think you see this so much in a shop as in the field. In a shop situation, FCAW is easier to have and use. If you are needing high depositing welding 60 feet in the air, or in a wide open situation where wind cannot be blocked or controlled, the 702X SMAW is better. The equipment is a stinger, ground and a welder.
- By weldwade (***) Date 10-13-2010 20:49
Nope. When we run LH its XX18 or 11018. I like 7024 much better than 7028 it's faster in my opinion. We still burn a bunch of stick due to accessability and time in the field over FCAW. In the shop though almost everything is GMAW, FCAW and GTAW.
- By 02pwrstroke Date 10-15-2010 04:43
Last shop I worked at we used 7028 in the shop just cause we didn't feel like dragging the mig machine around. the shop i work at now uses 6027.
