Up Topic Welding Industry / Technical Discussions / Miller Syncrowave 350LX, Can it be powered with 220?
- - By TheSavvy1 (**) Date 01-05-2011 14:31
Just purchased 7 used Syncrowaves, need to facilitate them into our facility. We will be welding light gauge stainless and I really would like to stay away from the 480 setup. Can these run on 220?
Parent - By DaveBoyer (*****) Date 01-06-2011 02:35 Edited 01-06-2011 02:40
They can be wired for 230V, but if You have higher voltage available, use it. The amperage will be lower, and the wire to each machine smaller and cheaper.
http://www.millerwelds.com/om/o363ag_mil.pdf
Look at the chart in section 3-6
Parent - - By 522029 (***) Date 01-07-2011 12:32
If you have 480 service in your facility, why would you not want to use that voltage?
Griff
Parent - By TheSavvy1 (**) Date 01-27-2011 12:26
Unfortunaltey we do not have 480. But we are entertaining it. Very large expence approx 35K, from the first quote I recived.
Just looking for the most cost effective way to set these up. We will only be welding light gauge stainless, so I never see us welding over 70-100 amps.
- By thewelderson (*) Date 01-05-2011 22:45
Yes, but wide open they can pull close to 125amps unless they have the power factor correction option installed... around 100amps. -Lou
